TRG....CHIMNEY FLASHING DETAIL QUESTION
« Back To Roofers TalkRoofing God or anyone else......can you guys post a picture of how to flash a chimney properly using a SA cap?
Do I need a cant strip around chimney? Do you just run base up chimney then do the same with cap sheet, then termination bar with sealant? What about corners?
Thanks!
I am going with either Flintlastic or Liberty 2 ply system.
TRG......I lost your phone number!!>>>
Vaa Fakaosifolau Said:Ed said: Vaa, I thought you told me that they do not specify cant strips along the perimeter walls, when I asked you a while back about your 90* turn up from the flat to the wall details. EdNot on PVC membrane, but its normal proceedure on torchon.
I could have sworn that the question I asked you was about cant strips from a modified torch down job you had photos of.
Ed>>>
Thanks for drawing Vaa, that was helpful.....I have no inside corners, just a chimney and I may just tear it down and go over the hole :ohmy:>>>
Vaa,
Ed>>>
Thanks Vaaaa.....I sure appreciate you all being understanding and helping me out. Any other times, I would be subbing this stuff out...but as hard as work is to come by right now, I figure I better learn to do it.
Thanks again, Randy>>>
