Sprayable bonding adhesive/Fast install
« Back To Roofers TalkI was talking with another contractor that was telling me about using a spray form of bonding adhesive for single ply. Said it was tons faster than rollers. Anyone have any experience with this? Any manufacturers recommended?
As a side note, in a tear-off situation, what is the fastest systems you use?>>>
It can be sprayed, a roller is still needed to get any misses and blobs, no masking, tarping required. A lot faster.>>>
IRS is the only mfr that I know of with a sprayable EPDM bonding adhesive. It's green, stringy and expensive, but should go down extremely fast. Have had it demonstrated in my shop, but never used it.>>>
Firestone has adhesive you can spray for single ply.....but you have to back roll it, still sounds faster but I would sure hate to clean the sprayer :ohmy:>>>
Just completed Carlisle EPDM and TPO seminars in PA and the instructor said adhesive is always applied with a roller at the correct coverage rate. Use a mechanically fastened system and you don't need any adhesive. If your talking about installing ISO, this can be installed with foam adhesive.>>>
Spray form or foam?>>>
