Remember This Old Topic? - LINE SNAPPING
« Back To Roofers TalkTOPIC-Line Snapping COPPERMAN- My motto is you wouldn't hire a cabinet maker that didn't use a square or level because you expect him to do perfect work. I am also a paid pro so I will always use lines to keep it perfect.
OLD SCHOOL- I use a tape measure and I always snap lines.
TINNER- I at least get reference marks somewhere.
TRG- I use a tape measure and I always snap lines.
LANNY- I have roofed for 39 years. I have never snapped a line nor have I ever worked with anyone who had. I worked for 10 different roofing colors in my early years and never once saw anyone snap a line. I started out with a comp ax with a gauge on it. Now the guns have gauges. Why do I need lines?
SEEN-IT-ALL- Must be a West Coast things as I hard ever use one either. With all the rain-mist-dew how would the chalk ever stay on the paper?
ROOFSCAPE- I've had the same chalk lines for about 11 years and never once refilled it! Keep a plastic orange one for carpentry and vinyl and that's it. For years I never chalked a line unless it was a looooong eave or a really tall rake. Even then, I would pop my two on the rake and one on the second row of the eave. I was taught well. I'm good at what I do. Not all my roofs are flawless. But you would never look at one and say "he should have chalked a line". You might spot something else, but that won't be it! I never once used a chalk on a hip roof. I'm referring to shingle only btw. You do it enough, you get that "eye. That head tilting, head swaying, flawless beam of perfection "eye". Beats a chalk any day. Oh and I've never in my life seen one roofer pop lines ever row like they show on Bob Villa and other home improvement shows. That's totally ridiculous! If I had an employee do that, I would send him home.
CIAK- We would run the felt paper straight and follow the lines on the felt.
JED- I use a tape measure and I always snap lines. Never met a shingler yet capable of doing a decent job without lines. Heard all the talk though. When the eaves runs out and they hit those extra inches at the ridge.
OLD N BROKEN- Well then Jed, you should come up to Idaho and I'll introduce myself to ya. I'll take you around the lakes and show you my work, of which a chalkline was RARELY used.
OLD SCHOOL- IF you can run the shingles straight and true, (no more than 1/8 of an inch variation up or down) on the length of the roof, and they are also parallel to the ridge in the same manner when you reach it, and there are no extra rows of shingles ever, and if you are using 3-1's and the cutouts always line up straight and you catch the layout over the dormers, AND you can do all of those things WITHOUT lines, you are a better roofer than I. If you cannot, then strike the damn lines and stop lying to us. Every 4 or 6 courses is plenty as a reference. Would you want to use a carpenter that didn't strike lines to layout the building? Would you use a concrete man that didn't use a line or a laser to set a grade? Give me a break!
ROOFS R US- Unless the run is really a very long line where you might have one half to a full inch of difference at the started course and hen the second course was out of whack-then you would need to chalk a line at the bottom of the second course of shingles. To also keep it straight as you roof several courses- measure from the ridge down to your shingle course. You do this all the way across and then you can determine where and how far up or down you are. Thus, you can then prepare to run your lines to keep the courses straight. But there are some houses where because of circumstances and size you do not have to chalk so many lines. It is also very good to chalk lines when you are starting to shingle up in your valley and want a measured and chalked set-over into the valley for proper coverage. The chalk line can be a very valuable tool if you know how to properly chalk those lines up and down.
OLD SCHOOL- That is my point! We are some of the very few roofers in this town that strike lines. I have seen some nice jobs done without them, and at the same time, I have seen some awful messes. Courses of shingles that vary an inch or so, 3 and 4, extra courses that start from nothing along the ridge, short courses and long courses, "Snakes" for crying out loud. I was on a slate repair last week and it was mostly done very well. On one side however, the courses varied from 6 all the way up to 9 inch exposure! Now tell me, how could they do that? It is important for me to know exactly where the roof is out of square and how much BEFORE I ever lay a shingle. The only way to do that is to measure and strike lines. That is my opinion and that is how I roll.
MISCREANT- I know a few guys that can put them on pretty straight with no lines, a bit of a wave, but more or less straight enough to get paid. Some of the problems with not snapping lines is that: 1) They won't be as straight, a roof that has shingles installed laser straight "pops" when you compare it to an unlined roof. 2) You can have less experienced roofers installing shingles in a very satisfactory manner. I don't want to pay a guy to install a couple of hundred crooked roofs while he figures out how to install them straight with no lines. 30 No matter who you are, you can install shingles faster with lines snapped. That converts into more money to you.
EGG- I remember when I was too fast to be bothered with snapping lines except on valleys, hips, and transferring patterns through intersecting obstacles. I preferred working alone on my own pieces and it is fair to say that snapping lines by yourself is a bit of a hindrance. If you are going to paceset or work with others, it's a bit more problematic. The rookie will inevitably let the shingle slip under his gage every now and then and fail to notice it until too late. Everybody gages a tad differently and twenty whiskers makes a bunch.
It's hard to find someone willing to hold the stupid end. I always snap the first two courses now and verify the framing accuracy. I always take a reading and snap a line whenever anything starts moving. Laser straight does in fact "pop". I have to admit it. And that's after decades behind my belt without snapping very many lines. I will never snap every course. The day I am required to do that is the day that I quit.
MYWOODY- The test is very simple. All of you "eye" guys, the next time you're confident by eye that something is perfectly straight, check it with a chalk line. Only then will you be ready to discuss whether or not you have the eye.
OLD SCHOOL- Every 4-6 courses is plenty! I was working with a bunch of volunteers on a church roof once that we struck lines for every course. 20 "helper" on the roof and not one was a roofer, but they all wanted to help. The lines worked wonders. With laminates, at least you guys don't have to line up the cutouts. That is where the lines are really important. In the West Coast however, I don't think they line them up. Different strokes!
GAK-I snap a line when I need to. On 3 tabs usually one to get started. Another one when going around a chimney or dormer. Usually snap the valleys and sometimes the hips. I encourage my crew to snap lines. I don't want them getting through their learning curve on my jobs.
ROBERT- I'm a line popping crazy man.
:laugh: Yes. And if she does it in a sloppy way, blame it on Lack of Table Setting Licensing :laugh:
I think I'll start having my 8 yr old daughter snap lines on the dining room table so as we can have 1/4" tolerance at edge of table with silverware & plate settings.
Honestly let's agree to dis agree. I refuse to hire anyone who does not snap lines. No loss at all on my part. Plenty of insurance scammers who would be glad to have them
Always racked my 3tabs, never had a problem. Not a one. I'm told it's wrong but I don't live on Florida's Coast either.... :)
Horizontal lines ......we have 1/4" tolerance at the ridge.
Snapping horizontal lines makes as much sense as the "racking" phenomena......There, that oughta' stir things up a bit more!
I'm sorry.....LOL - JK'g.....
How about, Oh I don't know.........LAYOUT? :laugh:
Who needs a blueprint anyway
Hey boss, I cut it three times and it is still too short!
There is no "free-styling".....There is a gauge on the hatchet or gun - The craftsman should know how to utilize the tools of the craft.
As to the carpenter analogy - When framing, there most certainly is situations that require a more custom/precise fit; Pulling out a tape or chaulk line, would actually prove less accurate/proficient - such as top plates, sills, let-in braces, fire-blocking, trimmers, plumb/lining walls, etc.....Now that I think of it, there's a significant part of carpentry, (framing anyhow), that's accomplished w/o tapes/chaulk lines.....Not a good analogy.
So would you hire a carpenter who actually marks his cuts, or is free styling it OK? After all.....
If I hired a guy and he couldn't run straight courses w/o snapping lines that would be his last day.
This is pretty mild compared to some of the last discussions. Hey, I don't care how you keep the roof straight as long as it is straight. I would be that most people would prove how straight it is with a line though. Nuff said!
Well, I have all kinds of chalk and several kinds of chalk lines. When I do a lay-out for any kind of tile I snap lines in both directions with a chalk that doesn't wash off. That way I can see the finished roof before I even start loading.
When I'm doing shakes, I use a tape measure to check bldg at start and monitor progress. The interply felt is the line.
When I'm doing comp, I use lines where I need to. Just squeezed in a little gable garage roof yesterday and didn't need a line at all. Hung the gutter, set the underlayment straight, and guaged it all. Had the chalk line with me the whole time and never needed to pull it out of the pouch.
Wouldn't dream of taking a chance like that on a long or complicated surface. I don't have a bunch of guys who let their minds drift off to what they're going to do when the day is over or what they did yesterday or the color of the socks they're going to buy or where they can get their bag of chips on the way home. I just pay attention to what I'm doing and make sure I do or use anything necessary to turn out a sweet product. That's my policy and that's my story and I'm sticking to it. I'll say this: valleys and flared rakes and dormers will humble anyone who refuses to use a chalkline. Big-time.
We snap lines every course, every roof. Been that way for 34 years. G-tape makes it easier.
I think Vickie is trying to resurrect G-Tape.......
