R-value of single ply?
« Back To Roofers TalkWithout insulation, TPO, PVC, EPDM has, what, about .5 R-value would you say? Doing some marketing, want to be accurate.
I'd be shocked if it was that high. I've never bothered to try and assign an R to any water proofing. Thermal mass of a thick BUR with gravel is probably the only only surfacing that would have any useful energy efficiency and even that's negligible.
Unless there is sun radiation, both sides of a single ply will be the same temp. Conductive heat transfer or something. (I'm just trying to take the discussion up to the 8th grade level to annoy Tim.)
I did not know it has any R-value
negligible by themselves...
