RLW pinned ad
Forum pinned ad
Painter drove nails through roof shingles
December 20, 2016 at 3:30 p.m.
mariopoli
I had my house painted. The painter secured new facia boards by driving 4 inch nails through the roof shingles. If I do not fix this eventualy the plywood under the shigles will rot. What is the correct fix for this?
December 21, 2016 at 11:09 p.m.
mariopoli
Vaa Fakaosifolau Said: Why on earth would you put a facia over shingles? Unless its a 2 storey or a dormer and the fascia overlaps the roof below. Photos would help understand what you are saying.
December 20, 2016 at 11:55 p.m.
Probably not four inch. Probably three and a half inch 16d. ;) I'm curious. The most likely scenario as you seem to indicate is barge rafter below & flush with the plywood and new fascia covering the existing barge, otherwise the raw plywood edge would be showing above the new fascia.
If the edge of the plywood is showing, you need metal nosing or a shingle mould. That's going to require some serious work now.
Information pinned ad
IKO -  Ad - ARMOURZONE
