paint modified???
« Back To Roofers TalkCan you paint granule surface modified to match shingles
Use hydro-stop finish coat. You can get it to almost any color and it is a UV protectant. www.hydro-stop.com
---Best to start with the color you want. If you have to paint I would research what paint might work or at least last more than a few years. It could get quite ugly if it starts to fail. Lanny
I don't see why not. You will have to watch out for the expansion/contraction rates of the modified against the paint though, it will almost certainly be different and subsequently crack. You know you can get modified in different colors right? Soprema even does red and blue.
