Modifications to metal roof
April 10, 2017 at 4:51 p.m.
same
Im going to install a gulfcoast supply versalok metal roof. This is a standing seam mechanically sealed hidden fastener roof approved for High Velocity Hurricane Zones (HVHZ), including Miami-Date.
My goal is to hurricane proof my home with one of the strongest metal roofs available. I am also doing other things to my home to make it very strong against winds. Those other things are outside the scope of this thread.
On the gulfcoast supply versalok roof I had previously decided to omit the gable rake cleats and eave flashing cleats. The only purpose of the cleats is to continue the hidden faster design.
To avoid having panel seams that intersect the vent boots and the chimney, Im starting at one edge with a partial width panel. Im thinking of cutting this panel several inches wider then needed and folding that edge down and screwing it to my fascia. Therefore not needing the gable rake.
please look at the images below and this company gable rake install video here: https://vimeopro.com/gulfcoastsupply/standing-seam/video/52086299
Images: https://imgur.com/a/84Bh0
thoughts? pa
April 25, 2017 at 12:51 a.m.
same
I think I found a better method. See image here http://imgur.com/a/qIoQl. Your thoughts? http://forum.rooferscoffeeshop.com/users/same/
April 11, 2017 at 10:25 p.m.
Do you have a metal brake that long? What I have done is to bend a starter piece that you can slide the edge of the metal into, with a caulk joint to seal it and hold it down. The piece is screwed or nailed down, but the joint allows for the hiding of the slit edge and also holding it down. We literally can install all of the rakes and ridges before we install any of the panels.
April 11, 2017 at 8:57 a.m.
same
14' 10"
Why when on this page, if i want to reply, I cant. there is NO way to log on, however, there is a create new account button.?? I moved back to the root page which allowed me to log on, then I had to find this post page again to reply.
pa
April 10, 2017 at 9:18 p.m.
That would work, but you are going to have a hard time folding it even all the way down depending on how long the rake is.
April 10, 2017 at 4:56 p.m.
twill59
We usually just move the plumbing pipes.
Sika -  Ad - 5% Off
Malarkey-Dec--Ad-250x265
