Directory pinned ad
FlashCo -  ad - Edge
insulating question
March 29, 2015 at 7:47 p.m.
roofrat
Greetings all from the great white north.I have an insulating question i would like to get some feedback on.I have a backsplit house 4/12 pitch just reshingled it last year.All the soffit venting and roof vents are working as they should.What i would like to do,to increase my R value is remove all the blown in fibreglass insulation then insulate with 3 inch polyiso between the trusses then blow the fibreglass back on top of it.A 6 mil poly vapour barrier is already in place(obviously under the drywall).My question is..am i setting myself up for a huge headache because im mixing the two different types of insulation?And am i going to create moisture by doing so?The reason for the polyiso is that it is no cost to me whatsoever.If it means anything i live about an hour east of Toronto and we do get some bone chilling weather here.Thanks.
March 29, 2015 at 8:40 p.m.
You shouldn't be! The ISO on top of the ceiling below is just act as an other vapor barrier, and the 3 inches of ISO will give you R21 with no voids. The fiberglass over that will just increase the r factor and if you do in fact have adequate ventilation and air movement, it should work like a charm. by the way, what is a splitback?
Directory pinned ad
