Hailwatch Service?
« Back To Roofers TalkI know this has probably been asked but I couldnt find it in the search. Can someone explain to me what Hailwatch is? Is it worth having? Do you only get 1 report when you purchase the service?
Thanks!
Randy
no problem brother,
Thanks Tico.....that site is cool. I have always used NOAA.....but never seen hail.org.
hailwatch .com is A paid service. i get as much info going to the NOAA site,put hail in the search engine and then about 2/3 down the page you see storm prediction.it will give you location by size,closest town/city and county. then g to hail.org.on the primary page, on the right you'll see the header for MAPS.the first one will be view hailstorm maps,click it. then once the window opens you'll have a map thats gonna indicate loations specifically.the yellow is up to one inch,the green up to 3 inches,and the blue is 3 and greater.you can scroll your mouse to resize the map larger,switch it to satellite and actually see the neighborhoods and the home density and the roof sizes and designs.
P.S. the second under maps is the prediction.it will give you centers and swaths. like today,it has swaths for rain,along with hail predictions. todays is from just east of el paso,through Houston up through the alley of OK.,missouri,up through indiana and across the top and all the way to Conn.
