asdf12
Polyglass -  Ad - Polyfresko
Get the Best Roofing Solution
October 11, 2013 at 11:49 a.m.
sammyleroy
If running water doesn't reveal the exact location of the leak, donate be timid. Start removing shingles in the suspect area. With them removed, they'll be evidence of the leak and you'll be able to track it down right to the source. You'll see discolored felt paper or water-stained or even rotted wood directly below and around it.
October 24, 2013 at 12:37 p.m.
I am suspicious about herlin wilson. I think it's a plant designed to eventually plug whatever he's selling.
October 24, 2013 at 6:16 a.m.
Wow Wilson. It is leaking at the peak eh? Maybe we could tear off some of the shingles above the peak....Nah, I guess that wouldn't work too well would it?
October 24, 2013 at 1:53 a.m.
kcmedia
Nice tip, Surely will try it.
October 23, 2013 at 10:59 p.m.
herlinwilson
I had gone through the posts. From a few days onwards, I am facing a problem with water leakage at the top of home roof. Where can I find the best details about the roof repairing services ? Please provide me details. Any kind of information is greatly accepted...
roofing contractor
October 17, 2013 at 5:16 p.m.
Aw common Vickie, We know that, we were just playing with him.
October 17, 2013 at 9:40 a.m.
I think Sammy is just trying to get people to his website.
October 14, 2013 at 7:53 a.m.
GSD
Estimate ? I'm not touching the roof. I've been doing it long enough that I will have a list of what the cause of the problem is in a probability order and will give the price accordingly.
repair? I will start going down that list until I get it. most likely its the first one or two.
Now, depending on the leak, where it is, where its running in the house, whats on the roof , etc. will determine if I do as you described.
October 14, 2013 at 7:12 a.m.
Are you telling us to make the clients roof leak again on a perfectly good sunny day and while doing an estimate we should start tearing into the roof? What if they don't hire you?
Why don't you try learning and knowing all the things that cause leaks and all the solutions that fix them.
That way you could just find a reference point inside the home such as a window edge or maybe from a point in the attic, take a quick measurement, then do the same on the roof. At that point you will be standing right on top of the leak.
October 12, 2013 at 3:40 p.m.
Ok, ok I've been told a day with out sunshine is like, you know, night. Please man your dealing with pros here. Of course it could be a play on words or better yet stating the obvious . Welcome Sammy B) :) :) B) Deep Down In Florida Where The Sun Shines Damn Near Every Day
October 11, 2013 at 11:59 p.m.
I'm going to have to try that on my next repair. I can't understand why I've never thought of that. Can I donate and be timid too?
October 11, 2013 at 7:40 p.m.
Wow Sammy, What a concept!
asdf12
S-5! -  Ad - Snow Guard
