RLW pinned ad
FlashCo -  ad - Edge
Directory pinned ad
Furnace Vent Issue
December 17, 2009 at 5:19 a.m.
In the last couple months I have been called out to look at a leak around a furnace vent at two seperate propertys. That in itself sounds routine but these two were not leaking from the roof itself. Inside the attic the furnace vent pipes connected to another piece of pipe just a few feet below the roof line. The water stains started at that connection. The water was coming from "inside" the pipe itself and getting out at the connection and running down from there. One of them 2 stories running down all the way to the basement before revealing a leak on the garage floor. lol The furnace vent pipes were both double pipes seperated by only about 1/16th of an inch. I took the top off the last one from the roof and it was all rusty on the inside. Not the outside. I bent back the inside pipe and stuck my finger down about two inches between the two pipes and when i pulled it back out there was moist rust on my finger. Im still not 100% sure how the water is getting in there but i put a new top on and hopefully that will stop the problem. Anyone else ran into this before?
December 23, 2009 at 8:20 a.m.
A couple years back I was installing a roof with a higher profile tile. The furnace guy had supplied an Oatey-style flashing. I told the builder I needed a lead flashing and the furnace guy brought a lead flashing and told me I'd have to cut off the pvc cone on top to get it on and gave me a metal cap to fit back on over the lead. The people move into the house in the Summer.
The next winter, the owner claims he's hearing water dripping in the wall. I check for leaks twice and find everything dry under the tile. On the third trip, it hadn't rained and was just cold. That's when I figured out water was condensing on the underside of the metal cap and dripping back down the pipe. There was an elbow in the pipe in the wall just inches from the master bedroom headboard that was driving the homeowners crazy when the drips hit at that point. The furnace guy made a new pvc cone assembly for me to glue on top of the pipe and the dripping disappeared.
December 23, 2009 at 6:06 a.m.
The Roofing God
you need a gallery to post them in.then you can use the url to post them wherever,I don`t think we have the option to add pics to our albums here anymore,but you can post job pics at Dennis`s site www.roofingcontractorreview.com,he has upload buttons,so you just click it and it goes straight to your computer--you can upload digital pics to your computer by removing the scan disc card from your camera,and plugging it into your computer-don`t really need the printers and stuff,but once you get all your pics on your computer,it`s easy to make cd`s of your jobs thast you can show to potential customers in their homes,I also find taking a picture for the customer to see ,eliminates a lot of extra questions,and you don`t have to carry them onto the roof to see their problems-some of the digital cameras even have cords to link to the HO`S TV OR COMPUTER so they can see everything in detail,you`d be surprize what a help it is for sales
December 22, 2009 at 5:47 p.m.
I don't have any and if i did i wouldn't know how to post them. lol I went out and bought 3 digital cameras, printers, adapters, etc. and now they are all gone. Never needed any pictures anyways so i just gave up.
December 22, 2009 at 6:22 a.m.
The Roofing God
Where`s your pics Willie ?
December 21, 2009 at 9:56 a.m.
elcid
Its been a long time, but I seem to remember that there is 3 or 3/10 gallons of water per 1000 cubic ft. of gas. I have a hi-efficiency heater and hot water boiler, and moisture pours out of the PVC flue w/ a positive exhaust that is horizontal(winter and summer.) On gravity flues, this excessive moisture should condense on the first cold surface it finds.
December 20, 2009 at 5:58 a.m.
The Roofing God
you probably have an oil cap versus a propane cap,the oil burns hotter,and it`s said any water getting into pipe will evaporate,but they will rust out a pipe on a propane burner because propane doesn`t burn as hot,the oil ones are filtered with mesh screen,and the propane are louvred?(look for type b propane cap) so water doesn`t enter. See it all the time where a chimney cleaning co will install the wrong caps,and cause the problems-I`ve even seen heat pipes with chimney caps on them,Try and point out the problem to the homeowners,and they don`t want to believe you,"What do you mean,That`s brand new !"-Yup,and you`ll have brand new damage from it-lol
December 17, 2009 at 6:15 p.m.
Seenitall you lost me. Its not a chimney just a heater vent exhaust. Copperman you might have something there i dont know becuase he says it only leaks when its raining. Does it only condensate during rain? When the vent is heated up and the rain is cold? Is the customer mistaken about only during a rain? lol I think i will call him and ask him if he put in a new furnace recently! lol
December 17, 2009 at 5:29 p.m.
Most likely this issue was caused by miscommunication between the heating guy and the roofer. The heating guy mounted his roof apron at the felt level. The roofer lifted it up to the level of the tile, pulling apart the seam in an inaccessable attic.
There's nearby prepainted step flashing that has rust coming from the underside.
December 17, 2009 at 4:46 p.m.
Was there a new furnace installed that is causing the condensation. Some of the high efficiency furnaces require PVC piping because of the condensation they create
December 17, 2009 at 2:59 p.m.
Does most of your rain come from one direction? Sometimes if a chimney cap is sloped for the rain to drip off on the side of a prevailing wind, the wind will blow the drips down the pipe and cause it to leak. Have had lots of these over the years. Try sloping the cap to drip away from any prevailing wind direction or make a shield out of some metal flashing and screw onto the cap as a rain deflector.
December 17, 2009 at 12:25 p.m.
Hi Guys, These two are strange ones. Woody, the stains on the pipes begin inside the attic at the connection point of the pipes shown in the lower right corner of your picture. There are no stains whatsoever coming from that point up and absolutely nothing at all wrong with the roof. That includes height of the vent pipe and everything else. The base of the flange is in excellent condition as well as the outside of the vent pipe. No rust whatsoever on the outside. Only on the inside. lol And there is no rust on the inside of the inner pipe. The rust is between the two pipes and nowhere else. Also both customers say it only leaks when its raining ruling out condensation. ( for the most part ) Its really strange because in all my years of doing repairs i had never seen this situation before until this year and now i've seen it twice. Im not 100% sure what the flick is going on but im leaning toward the caps being the problem. lol
December 17, 2009 at 11:54 a.m.
elcid
IMHO nothing more than condensation contingent on tightness of flange to roof. I always thought the Amervents had a double liner w/ at least 1" separation. Could possibly be caused by insufficient flue height, which should normally be above highest point of the roof, in order to exhaust gas properly. If not, backdrafts can occur, and flue gas has considerable amount of moisture within it regardless of the temperature. With a short stack height, backdraft diverters are commercially available.
December 17, 2009 at 9:35 a.m.
kage
Could they be sweating?and not leaking.
December 17, 2009 at 9:02 a.m.
I posted a little while ago an incident fron heating pipes coming apart and the resulting rust from the moist air getting in the attic. There was also charring of the plywood nearly causing a fire. Ironically, it probably didn't burn because of the heavy condensation on the plywood. I had a hard time communicating what was going on to the homeowners, they were a Japanese couple whose English didn't go much beyond, "Please, you wear booties in our house."
Polyglass -  Ad - Polyfresko
NRCA -  - Roofing week
