SOPREMA -  Ad - Mini-Macaden
Malarkey-Dec--Ad-250x265
Any build cone roofs?
October 4, 2009 at 8:50 p.m.
We did an addition several years back and in the process we got to build this cone entrance to match another on the house. I had roofed the building about 18 years ago with tile and made this one match the old. Pretty neat project!
http://picasaweb.google.com/crookston.john4/ConeRoofing?authkey=Gv1sRgCMm95rjVxpn7Fw#
October 8, 2009 at 4:53 p.m.
It is concrete tile. I have never seen Madonna's nipple, but I suppose if you have seen one, you have seen them both.
I installED grace I& W over the whole thing before I installed the tiles. It is a chore to try and keep everything breaking correctly. As far as trying to cut all of the pieces when you roof one, make a jig for it. Here is the article I wrote last year about roofing them.
http://www.traditionalroofing.com/TR7_turrets.html
October 8, 2009 at 7:58 a.m.
How does that not leak? I see several joints over joints on that roof. Are you relying on base paper under it? I'm no tile guy so I'm just curious as to what keeps it dry
October 8, 2009 at 7:39 a.m.
For some reason, when I look at that top piece, I think of Madonna's nipple.
October 8, 2009 at 7:13 a.m.
max
looks good, cept i would have a full course at the top :( r those pineshakes?
October 8, 2009 at 12:27 a.m.
lanny
I have always called those turrets. I shingled one last year that required a lot of cutting the closer I got to the top. ---Very nice job. Did you fabricate that top piece? Lanny
October 5, 2009 at 8:09 a.m.
tico
yes,when I framed in NC we built high end mostly.all stick built. I've built half radius,with rooftop and ceiling, suited. I've biult many octagonal and conical. the octagonals,when I worked for others were A bitch.the laed would want to cut the rafters to form fit.it was so burdening. then when I started to frame for myself I woild get A 6x6.cut the corners off of it to make it identical on 8 sides.I would then cut it's height from the top of the ceiling joist to the proper rise and have the best support and work face to attach the rafters to.
October 4, 2009 at 9:42 p.m.
Roof Doctors USA
Nice looking job.
NRCA -  - Roofing week
Information pinned ad
